Can Project Board can be copy ?
Allen Lee October 31, 2023 edited
Hi everyone !
JIRA Board ( include columns & status ) can be copy ?
Ex. create a jira board as template,when I create a new project can use that
      no need to repeat work
Asha Goyal
October 31, 2023
Hi @Allen Lee
Yes you can copy a board
To copy a board in Jira Software Cloud:
  • From the global navigation at the top of the page, select the search field or ( press /)
  • Select Go to all: Boards
  • Select Create board in the upper right of the screen
  • Find the board you want to copy
  • Select Copy from the menu on the right side
Hope it helps
thanks @Asha Goyal
But my question is when i create a new project ( A )
I want to use Project ( B ) jira board
use your way,copy jira board will stay in original project ( A )
thanks !
Asha Goyal
November 1, 2023
You can copy board from Your work ->Board . Click three dots and you'll see the 'Copy' option
Open the copied board and follow the navigation: click on 3 dots on the top right corner --> 'Configure Board'  --> Saved filter (Edit filter query) and change the name of the project.
Hope it helps.
Like Allen Lee likes this
Allen Lee November 1, 2023
thanks @Asha Goyal !!!!!
it's work for me
Register now
