×Is there a way in Jira, to convert one existing field/section/paragraph (plain txt) into a rich txt one, without replacing it? We have a lot of data there and we do not want to lose it.
Example:
this >to become like this >
Any workaround to convert this without losing all info, previously added in plain txt ?
Yes you can do this. You need to modify the Field Configuration to make it rich text - to do this:
Note: You can also get to the Field Configuration page via Settings > Issues > Field Configurations
Ste
@Ste Wright Thanks, I am going through the steps and got blocked at
So right after I click Actions > Edit Fields, I see this
When I tried the search on the top right, it gave me this
I found the field and see where it says Renderer, but cannot find there to change it from
You're on the Field Configuration Scheme page, rather than Field Configuration. If you click on the hyperlinked Field Config (i.e Copy of [FMP] Default Field Configuration) you should see the search box just above the Name column.
Here's another way you can get there:
Ste
