Can different sub-tasks listen to eachother?
Johan Söderström
I´m gonna try to simplify this by making a scenario:
I have three different issue types: Story, sub-task and test-task.
Story workflow is: To Do - In Progress - Test - Done
Sub task and test task have both different sub-workflows
  1. When all sub-tasks are done I want the Story to transfer to In progress (this is no problem).
  2. When all sub-tasks and test-tasks are done I want the Story to transfer to Test (this is a problem).
  3. If the test-task is Done before the sub-task nothing should happen to the story until the sub-task also is done(this is a problem).
As i understand it number 2 and 3 is not possible because there are no post-functions between the childs. Am I correct?
Nic Brough -Adaptavist-
September 9, 2016
Correct.  You'd need some code in the post-functions on the two sub-task workflows that could check the other sub-tasks on the parent for your business logic.
Johan Söderström
Thank´s Nic for your quick response. Could you please explain me or give an example how to do that?
September 9, 2016
I'm afraid that's where I have to let you down - you can't add such code to Cloud systems.
Johan Söderström
Thanks again for your answer.
Register today
