Can i change Jira Url?
serhatengin_nemutlu
September 13, 2020
Hi everyone,
i wanna change my jira url: https://testnemutluteam.atlassian.net
i wanna change with this url: https://serhatdeveloper.atlassian.net
how can i do this?
Prince Nyeche
September 13, 2020
Hi @serhatengin_nemutlu
You will need to Contact Support
Jira Guru
September 13, 2020
You can't modify the base Jira URL on a Cloud instance at this stage - you'll need to create a new instance then migrate your data across to it.
See this page for more information and instructions on how to do this.
Michael March
A few pointers on this:
  1. If you have addons with your cloud site, you'll may need to contact each addon vendor and have them update their configurations.
  2. 50% of the time when you export / import your site, there will be import problems. You might need to reach out to Atlassian or an Atlassian partner for help.
FREE
