Can i get the status that issue was when it was flagged?
Pedro Webster April 27, 2023
is it possible? is there a field or table that show that?
I wanna know what status is the most offensive of blocking my flow.
Yuliia_Borivets__SaaSJet_
Hi @Pedro Webster
For your request to get the status that issue was when it was flagged, I can suggest a solution from my team. If you're ok with plugins, check out Issue History for Jira. It stores all the past activities of the team.
You can add statuses and flagged fields to get the report.
Check out if it works for you with a 30-day free trial.
Trudy Claspill
You can manually review the History tab for the issue to find the dates when the status was changed and compare that to the date when the issue was flagged.
There is no field that you can query to get that information natively.
Going forward you could create a custom field and use automation to fill the field with the current status value when an issue is flagged. You would then be able to filter based on that custom field.
pheaps this workaround could solve my problem.
could you please send me the automation ?
i've tried this one but it dint work =(
Trudy Claspill
What type of field is "Status do Bloqueio"?
What does the Audit Log show for the rule execution?
Pedro Webster May 1, 2023
It is a Text Field (single line).
The audit log shows "success", but the field "status do Bloqueio" remains empty.
Trudy Claspill
You should not need to use the Advanced JSON Editing option.
You should be able to simply select the field using the Choose fields to set option.
You can then insert the smart value as the value you want to save in the field.
{{issue.status}} will save the unique numeric ID associated with the Status value.
{{issue.status.name}} will save the text name (i.e. Done, In Progress, To Do) of the status.
atlassian, atlassian community, loom ai, atlassian loom ai, loom, atlassian ai, record recaps of meetings, meeting recaps, loom recaps, share meeting recaps,
Loom’s guide to great meetings 📹
Register today!
