Can no longer view worklogs
paul o_connor November 23, 2020
Up until recently I've been able to view worklogs using the plugin.
Now for some reason I get a "something's gone wrong" message when I try to open them.
The icon that appears to the left of worklogs also appears to be grayed out.Capture.PNG
Typically I use chrome, so I tried forefox and got the same message.
I also tried from another device - same problem.
Any suggestions?
Paul
Angélica Luz
November 24, 2020
Hello Paul,
I can see that the Worklogs add-on is active on your site, but it's important to check if it's updated.
This information must be checked by a Jira administrator. They can go to Cog icon > Apps > Manage apps to see if an update is pending.
Please, ask your administrator to check this information.
If you still face issues, you can reach out to their support team:
Angélica
paul o_connor November 25, 2020
Thanks for the response.
No update pending, but they suggested I try using a different internet connection - so I tethered to my cell and that worked.
Go figure.
Like Angélica Luz likes this
Paweł Gesek
November 26, 2020 edited
Hello Paul
The problem seems to be a DNS issue caused by recent maintenance done by our domain registrar and it seems to randomly affect select users based on their location (the DNS server they are using). We are working with our provider to solve the issue, sorry for the inconvenience.
Paweł
Like 2 people like this
paul o_connor November 26, 2020
It's working now, thanks
Ruz Abdusamiev
February 11, 2021
Cool. Thank you for this tip.
