×Hi Team,
I like to use component feature for my project. But i can't see the option to select component. I try to create sub task and looking for components to assign the sub task to other team.
Please explain how i add component option for my project.
Thanks & Regards
Hi @Ramesh K R Components are not there for Team Managed project .
It is only available in Company Managed Project . So , you need to change to company manged project to use the components .
Thanks and Regards ,
Rishav kumar Gupta
Hi Rishav kumar Gupta ,
Thanks for your swift response.
Company Managed Project is free or we need to pay extra amount ?
There is no need to pay for company managed project !! As you can create a team managed project same way you can create company managed project .
**when it comes to pricing it only depends on the whether you are using free , standard , premium & enterprize plan.** So no need to worry you can create company managed project .
Hi Rishav kumar Gupta,
Thanks lot,
Can i use Backlog option in company managed project.
yes , definitely it will be there you can use it
thanks !!
Always Welcome :)
