Can't create sub-task in specific statuses
Gal Shamir June 28, 2022
How can I control the statuses that enable me to create sub-tasks?
While trying, I'm getting this error:
Transition is not authorized because current Issue's parent Issue should be in one of the following statuses: Open, In Progress, Reopened, Backlog, New, Assigned, Ready, Completed, Blocked, Testing, Ready For Testing, In Review, Confirmed
Assignee is empty
And I need to be able to create sub-tasks under 2 statuses that
Gal
Nic Brough -Adaptavist-
June 28, 2022
That's being done by a validator that your admins have put into your sub-task workflow.  You'll need to ask them to edit it and include the status you need.
