Can't find project location
Geylani Özçubukçu
Hello Jira Community,
I have a problem with a custom board I am trying to setup.
My project is a team managed scrum project.
I created filters that allow me to see multiple projects on one board, which is great but I can't share my new board with my team as I can't find my projects location listed on the field bellow:
Because of this assigned the location to my personal space.
How can I create a project location?
Or How can I share this board without it?
Geylani Özçubukçu
@John Funk Thanks for the article. I was able to connect my board to a new location. Now I need to find a way to be able to share it to my team and also find a way to show Subtasks.
John Funk
Hi Geylani - Welcome to the Atlassian Community!
I recently wrote an article that helps with creating a second board like what you have done. Check near the bottom of the article about the issue with the Location field and see if that helps:
https://community.atlassian.com/t5/Agile-articles/Creating-a-Second-Agile-Board-for-Team-Managed-or-JIra-Work/ba-p/2115018
John Funk
You need to share the filter used by the board for your team to be able to see the new board.
Like • Geylani Özçubukçu likes this
Geylani Özçubukçu
Hello John,
I shared the search filter used by the board from the menu bellow as well as shared the board. My team still can't access the board. Was this the step you suggested me to take?
John Funk
What type of project are you using? Team-managed? Company-managed? Jira Work Management?
If you click the Details link at the top of the filter instead of the Share button - who does it say it is "shared" with?
Geylani Özçubukçu
We are using a Team Managed project. I don't have a field where it shows whom I have shared the filter with.
John Funk
If it is the built-in board that comes with a Team-managed project, then the users you gave access to in the Project Access function should be able to see it.
Geylani Özçubukçu
Hello John,
I found a work around for my problem. I assigned my board to an old Classic project as location and I shared my search filter and made it public to my team. By doing these I was able access a board made up by multiple projects where the whole team can collaborate.
John Funk
Yep - that's the way to do it.  :-)
Register today
