Can't find where to add a project role
Tran Le July 28, 2020
I can't find where I can add the project role. Could you please give the detail guideline? Thanks
Best Regards
Tran Le
Ilze Schoeman
Go to Administration, System, then you will find 'project roles' on the left hand side under 'security' in the menu :)
Here what I got from the Security Tab. There's no place for choosing the project roles. Is it the wrong place?
Got where I can find it. Thank u :)
Like • Ilze Schoeman likes this
Reshma Begum {Appfire}
July 28, 2020
Hi @Tran Le ,
You can navigate to https://yoursite.atlassian.net/secure/project/ViewProjectRoles.jspa
and add the project roles.
Hope it helps!
Reshma
Thanks. I got it :)
Walter Buggenhout
Hi @Tran Le,
Have a look at the Jira documentation on managing project roles.
I can't find the place to add the project roles after going to Administrator/System/Security. Is there any wrong is my step. Here is what I got from the Security tab
Got where I can find it. Thank a lot for your help :)
