Hi! When generating release notes, I can't get the notes to generate in Markdown format.
When I change the format from HTML to Markdown, the "regenerate notes" button isn't clickable until I also change the layout or issue types. Even after changing the layout/issue types along with the format, whenever I click "regenerate notes" they just reload in HTML.
Any ideas?
Hi @Hannah Tillman -- Welcome to the Atlassian Community!
Here is the suggestion (bug?) to fix that behavior: https://jira.atlassian.com/browse/JRACLOUD-76412
Best regards,
Thanks you! :)
Register now
