Can't match Zephyr test cases from Jira's Issue Navigator
Roei
February 16, 2023 edited
edit:
Sorry, my bad, we're no longer using Zephyr for Jira but Zephyr Scale, so the test cases are not stored in JIra, hence not accessible by JQL.
For some reason I can't close this question.
Hello, I'm an end user (a software tester) of Jira Core Server 8.20 with the Zephyr for Jira plugin.
According to documentation I should be able to find Zephyr test cases using this JQL:
issuetype = Test
Quote from
Note that if you are just looking to search for a test, you can do that easily from JIRA's Issue Navigator. Tests are standard issue-types and can be searched on in the same way as you search any other issue-type.
source
But the JQL doesn't match Zephyr tests.
Can you tell me or direct me as to why?
Roei
February 18, 2023
Vamsi Kandala
February 16, 2023
Hi @Roei
Welcome to Atlassian community!
You can add something under 'Suggest an answer' and mark that as 'Answer' so that the question will be closed technically but any user can still add comments/ suggestions.
Vamsi
