×Trying to publish a workflow so i can edit it.. but it seems it always returned to be unpublished work flow.
I cannot see the option to publish workflow.
I did the below steps -
1. Created a new workflow scheme
2. Created a new workflow
However, the newly created workflow remains in 'Inactive' Status
Please help resolve this issue.
Mayuri
Hi Mayuri - Welcome to the Atlassian Community!
First, it is always better to post a brand new question than to add a question to an existing post, because only the couple of people on the post will see it versus dozens otherwise.
Workflows remain in an inactive status until the workflow scheme they are attached to are linked to a project. That's what makes the workflow (and the scheme) active.
Thanks for your response!
So by default a workflow got linked to my project. Now I've created a new workflow scheme and a new workflow. How do I deassociate the old workflow and link the new one?
Go to Project Settings for the Project
Then Workflows
Then click on the Switch Scheme button and select the new Workflow Scheme.
Hi Theya - Welcome to the Atlassian Community!
It's hard to tell what you are encountering. Can you give us a step by step what you are doing and what it is showing?
Tried restarting my login. but still encountering the same
