Can't use issueFunction in script runner enhanced search?
Narendra Kumar
Hi Team,
We are trying to use the following query : issueFunction in linkedIssuesOf("labels = 'XXXX'", "Contains")
But it says : Field 'issueFunction' does not exist or you do not have permission to view it.
We're on jira cloud version and having script-runner valid license.
Let us know the cause of this error.
Thank you in advance.
Narendra
Kristian Walker (Adaptavist)
Hi Narendra,
I can confirm that the error which you are recieveing is the one documented inside of the knowledge base article located here  which explains that inside of ScriptRunenr for Jira Cloud you must run these queries on the Enhanced Search page.
I hope this information helps.
Kristian
Kevin Chu
August 5, 2021
Hi Kristian, we have scriptrunner installed on jira cloud, but I'm not seeing what you're referencing in those docs to solve.    https://docs.adaptavist.com/sr4jc/latest/scriptrunner-enhanced-search/comparison-with-scriptrunner-for-jira-server
But it doesn't say what to use instead for cloud compatibility.  Can you please elaborate?
Becca April 9, 2022
To help other that may be struggling with this - I found that sometimes manually typing out the query in Jira Enhanced Search doesn't work or identify the function being used (see my above post for an example) - instead for reasons I don't know and which weren't clear via the documentation, I had to build the query using the provided query/function builder.
Cash Coyne
October 27, 2023
Yes!  TYVM!  This worked for me with the same issue!
Lior Cohen Amikam
February 26, 2025
Thank you very much! solved the issue.
Becca April 8, 2022
We're having the same problem:
1) Are trying to use the Jira scriptrunner advanced JQL function linkedIssuesOf
2) Exact JQL =
issueFunction in linkedIssuesOf("project = EVAL and resolution = unresolved","ADHOC to SDLC Relationship")
3) We are using ScriptRunner Enhanced Search in Jira Cloud (not the regular search toolbar)
4) We're getting the result: Function 'linkedIssuesOf' does not exist
Nic Brough -Adaptavist-
April 8, 2022
Kristian's answer is still right.
Jack Brickey
that function is associated w/ Scriptrunner. Do you have that addon?
Narendra Kumar
Yes @Jack Brickey  we're having the valid license of Scriptrunner.
Jack Brickey
In that case please see Kristian's answer as it is the correct answer.
Let's build A Rovo Agent 🤖
Save your spot
