Can there be two versions of the same issue type in a project?
Zack Lindberg May 21, 2020
My team wanted the ability to have bugs reported within a story so as not to have new bugs end up in the backlog when they're created. So I created another subtask issue type in the project that carries the Bug icon. This allows them to add bugs to a story similar to how they add subtasks to a story.
I am trying to associate a custom field to this new issuetype and cannot do it. The original subtask has the custom field but this new issue type doesn't despite being attached to the same screen scheme as the subtask.
Zack Lindberg May 26, 2020
Hey @Petter Gonçalves
I checked out both steps listed above. Here are the results.
1. The context of the custom field is for all issue types in any project.
2. The field is present on the field layout screen under issue layout.
The issue still persists. The orginal sub-task issue type carries the custom field while the newly created sub-task issue type (bug icon) fails to display the custom field.
Petter Gonçalves
May 22, 2020
Hello @Zack Lindberg
Thank you for reaching out.
Per your description, I understand you are not being able to add a custom field to a newly created sub-task issue type, despite the correct screen scheme is properly configured with the custom field. Is that correct?
I suggest checking the following steps to troubleshoot the problem:
  1. Navigate to Jira Settings > Issues > Custom fields > Click in the custom field you created and under the Contexts tab, check if that field is not restricted in the issue-type you created:
  2. Under project settings > Issue layout, double-check that the field is properly configured to display in issue view
Let us know if this information helps.
Let's build A Rovo Agent 🤖
Save your spot
