Can we Create Confluence Page From Jira Cloud use JMWE?
Tyas Iglecias
Hi Guys,
In my workflow, some states need input detail information in confluence
can JMWE make Jira cloud trigger to create Confluence Page?
Tyas
Alex Koxaras -Relational-
Hi @Tyas Iglecias
You can create a confluence page using webhooks and REST API with jira automation. No need for JMWE. You can use this post as a starting point to get you thinking https://community.atlassian.com/t5/Jira-articles/Automate-your-Confluence-documentation/ba-p/1771718
Tyas Iglecias
Hi @Alex Koxaras -Relational-
thanks for the articles, I think its for Create new Confluence Space (correct me if i'm wrong)
but I have specific Space ( Example : Space "A") for a number of page, need to be create from states changes
Example : I have states  Open > Requirement > Design > Testing
What I need, after states change to "requirement", jira trigger Confluence create page "Requirement" in  Space "A"
Like • Laura Holton _ACE Manchester_ likes this
Hey @Tyas Iglecias
Yes, you are correct. It's for creating a space. However, as I mentioned you, it's a great starting point to work your way through REST API and automation, and learn how to create a page on an existing confluence space.
Tyas Iglecias
thanks for the advice
David Fischer
Note that you can achieve the same using JMWE's callRest filter, for example in a Build-your-own post-function.
Tyas Iglecias
Hi @David Fischer
"you can achieve the same using JMWE's callRest filter" >> its mean we need to generate API token?
for my case :
can you give example how to build script "Build-your-own post-function"?
