Can we change Base Url in jira cloud
Udomsak Donkhampai
May 7, 2017
I found that we cannot edit base url. Is that true? or is any way work around.
Nic Brough -Adaptavist-
May 7, 2017
Correct, it cannot be changed on Cloud.
There is a request open for this, but there is no timeline.  Atlassian have not closed it, so they are not saying "no" yet.
Sam Hall
May 8, 2017
Fabio Racobaldo _Herzum_
June 1, 2023
Now it is possible
Please follow this page for further details and instructions on how you can access the feature: https://support.atlassian.com/organization-administration/docs/update-a-product-url/
Jerry Laster _Divim_ Inc__
This solution is still hosted under the atlassian.net domain. Is there a way to redirect or to have the jira instance to be at jira.mydomain.net?
June 24, 2018
Last year's answer still applies.
Temur Bekurishvili April 17, 2018
Is there any update on this issue?
Udomsak Donkhampai
April 17, 2018
I already buy server version and stop using cloud.
April 17, 2018
All updates on this are on the issue Sam linked to.  That's also where you should go to vote if you want to (comments here are not going to help the cause, and +1s are a total waste of time)
