I want to know if there is any way to display the results of only a selected number of testers in the dashboard where zephy gadget - Test execution scorecard by tester is used.
For example- In the elow list I am getting all the testers present in the system. Whereas I only want to display the data for 5 of these testers.
I do not see any filter that can be applied for tester while configuring the gadget,
Yes this is possible. Choose the Custom Query option (this has many filter options), and from the Test Execution box, select either Assigned To, or Executed By to select the tester who it was assigned to or who executed it.
Zephyr Scale has its own user community that can better serve questions like this and you can speak to other users here Zephyr Scale User Community
Hello @Andy Barbet ,
Thank you for the reply.
Can you please redirect me to the place where I will find the custom Query option as I do not see this anywhere in the gadget.
It's in the screenshot you attached to your post, but here's a more detailed explanation of how it works:
1) Click the Filter by dropdown
2) Select Custom Query
3) Select either Assigned to or Executed by
4) Select your testers (start typing their names to see options to select)
I recommend you use the Zephyr Scale community for questions like this. You will be able to speak to like-minded users, the SmartBear team actually monitor the forum, and you won't get spammed with answers that are upselling other solutions.
