Can we make multiple smart values in automation rule trigger.
Vishnu Vardhan Chenna
Hi Community!
I want automate the workflow with field value of status and the trigger is when field value changes based on this I need smart values for the trigger. for e.g i have 4 statuses open, in progress, resolved, done. and can we put multiple smart values in trigger?
Thanks.
John Funk
June 13, 2023
Hi Vishnu,
You shouldn't need smart values for the trigger for Statuses. Just add the condition for Issue Fields Condition, choose Status for the field and then Is One Of for the second listing. Finally add the status values.
Hi @John Funk
Actually we are using different issue types for these issue types we have different workflows. So I need automate one of issues types and its workflow.
John Funk
June 13, 2023
Can you share the rule that you have so far?
John Funk
June 13, 2023
You shouldn't use a Field Value Changed trigger for Status, you should use an Issue Transitioned trigger.
Like Vishnu Vardhan Chenna likes this
Hi @John Funk
It's working. thanks for the solution!
Vishnu Vardhan.
Like John Funk likes this
John Funk
June 13, 2023
Great! Glad you got that working.
