Can we update custom field Dropdown values by an API call??
Srikanth Vemuluri January 22, 2023
Hello All,
We want to Update dropdown values of a multi/single select custom field after certain time intervals by using an Web hook/Automation rule -"Send a Web request". Is it possible to update the particular field values?? If so please suggest how can we do it or using which tool in Jira cloud standard.
Srikanth Vemuluri
Alex Koxaras -Relational-
Hi @Srikanth Vemuluri
You can use a REST API call to update the values. Specifically this endpoint:
PUT /rest/api/3/field/{fieldId}/context/{contextId}/option
More info on the above endpoint can be found below:
https://developer.atlassian.com/cloud/jira/platform/rest/v3/api-group-issue-custom-field-options/#api-rest-api-3-field-fieldid-context-contextid-option-put
Let me know if the above helps.
Srikanth Vemuluri January 23, 2023
Hello @Alex Koxaras -Relational-
Thanks for the quick response. Will check the API with this end code.
Can you please tell me how can i get a context ID??
@Srikanth Vemuluri
  • Go to cog wheel > Issues > Custom fields
  • Find you custom field > click ellipsis menu > context and default value
  • Click on "Edit Configuration" on your available context
  • Upon loading check your browser's address bar and locate the word "ConfigSchemeId=XXXXX"
  • That XXXXX is the context ID
Like Srikanth Vemuluri likes this
Srikanth Vemuluri February 15, 2023
While using the Rest API above mentioned
/rest/api/3/field/customfield_26683/context/32498/option"
I'm using config scheme ID in place of Context ID. But it's not working for me. Can you please suggest on this
Srikanth
