Can you create a write to a file using scriptrunner for Jira Cloud?
chadunbehaun May 27, 2021
Requirement: Generate a CSV or Excel spreadsheet from a Scriptrunner job that contains a list of issues returned from JQL query.
I can get the field values I need but can't find an example of how to write them to a file. Any help would be appreciated in terms of where to start or some examples I can try out.
Tinker Fadoua
@chadunbehaun
Did you check ScriptRunner Examples?
https://docs.adaptavist.com
chadunbehaun May 28, 2021
Yes but didn't find an example of writing a file for Scriptrunner Cloud.  Plenty of examples for Server though.
Zita Bagi
July 25, 2022
Hi @chadunbehaun, have you found an answer to this?
Register now
