I have created labels to organize my automation rules. I have a label I no longer need and want to delete but do not see where I would go to delete it.
The edit function only allows me to change the name vs delete.
Did you figure this out?
I experimented, and when a label no longer has any rules assigned/associated, it vanishes within a second (or the next page refresh). So, it appears delete is auto-magic. :^)
Best regards,
Hi Bill,
Yes I noticed this myself just recently. Thank you for following up!
Best
Wondering if anyone has seen this: instead of disappearing, the labels are sticking around but with the "unused" underneath it.
Hi @Julia
What version of Jira are you using, Cloud or Server/Data Center?
I found this open defect for this symptom: https://jira.atlassian.com/browse/JIRAAUTOSERVER-299
And, for me I do not see the "UNUSED" indicator and unused labels disappear within a few seconds after a page refresh.
Best regards,
Thanks! I'm on Cloud version so that explains why I do not see that symptom. I recommend watching/voting for the ticket to see any progress.
Best regards,
@Bill Sheboy - your ticket was finally solved for Data Center! I ran into the same issue, and upgrading Jira Automation to version 8.1.2 gives you the option to Edit or Remove a label. 🙌
Awesome; progress!
Yes - as of the most recent version of Jira Automation for Data Center, you can access an “Edit” and “Delete” option when hovering above Rule labels on the admin screen.
