Can you order the pinned fields
Neil Heverly
November 6, 2020
So we now have the ability to pin fields to the top of the view, which is great.  I have a set of fields that i pinned to the top, but i would like those in a certain order, however, i can only unpin everything and then repin them in the order that i want to see them unless i am missing how they can be ordered.
Jerry Siskind
October 20, 2021 edited
Can we please have the ability to reorder the fields or at least lock the order in place. Its way too easy to click on the unpin button accidentally and lose your placement.
Deleted user December 11, 2020 edited
I also would like this feature to be built-in.
As a work-around I made the API call manually to set the pinned fields by copying the request from my browser's developer tools network tab and edited the payload to contain the fields and order that I wanted:
curl 'https://YOURSITE.atlassian.net/rest/api/2/mypreferences?key=jira.user.issue.details.pinned-fields.PROJECTKEY' \
-X 'PUT' \
-H 'content-type: application/json' \
... other headers including auth cookie ...
--data-binary 'components,11154,11151,versions,fixVersions,customfield_10952,customfield_10024,assignee' \
--compressed
Justin Stolle
August 12, 2022
Found this to be very useful, thanks! Mine worked like this:
curl "https://PROJECT.atlassian.net/rest/api/2/mypreferences?key=jira.user.issue.details.pinned-fields.PROJECTKEY" ^
-X "PUT" ^
-H "content-type: application/json" ^
-H "cookie: BLAHBLAH" ^
--data-binary "timetracking,timeoriginalestimate,customfield_10619,assignee,reporter,customfield_10007,priority"
November 6, 2020
Hi @Neil Heverly
According to this article, the order is based upon the order that you pin the fields:
https://community.atlassian.com/t5/Jira-discussions/Introducing-Pinned-Fields/m-p/1507918#M11941
Best regards,
