Sign up Log in
Can you update azure/AD from insight asset management
Scott Federman December 15, 2020
I have a client that is interested in using insight asset management. I understand there is integration to pull in data from azure/ad to insight/jira. But is it possible to make changes in insight and have them update azure/AD?
Mikko Meskanen December 16, 2020
Hey,
Insight azure app allows you to import data from Azure to Insight. App does not support syncing changes.
Hakan Bahadir
December 17, 2020
For synchronizing the changes in Insight, you can use the Insight Automation Framework. It is possible to define triggers, conditions, and actions. For example, when the department of a user is updated, you can execute a groovy script for updating Azure AD.
FYI
Hakan Bahadir
Solutions Engineer
Like Jon Johansen likes this
FREE
