Cannot find created insight objects
dhernandezs
Hello community!!
Currently, I create an object type field to fetch the information from the assets, but every time I create a new record in the assets, it doesn't return it to Jira.
I hope you can help me, thank you very much!!
Patrik Korovsky
November 25, 2022
Hi @dhernandezs
Have you tried using a link instead of a key?
dhernandezs
Hi @Patrik Korovsky
How can you use a link instead of the key?
Patrik Korovsky
November 25, 2022
If you hover over "IT-5777" from the first screenshot, you should get the link. This is my first idea though, not sure if it will help you.
