When using the basic search in Jira to specify a filter from the custom field "Severity" it is greyed out, with the red exclamation warning beside it stating:
Severity is not applicable for the current project and/or issue type
...despite:
Oddly enough I can still:
...so I know the data is there, Basic Search just won't hand it to me.
I can get it to work when I remove specific Issue Types and instead have the Custom Field apply to all of them. So is something wrong or is this intended behaviour?
I also noticed a field (In yellow) is not populating with Issue Types on the Configure Custom Field: Default Configuration Scheme page when I've selected specific ones:
What's my outcome? To only have certain fields for specific Issue Types as they don't apply to all of them in the Project. As some fields are "Required" it can be frustrating to be "Required" to enter a field when the Issue Type may be irrelevant.
Any help is much appreciated, I've been at this one for a while!
