I would like to add the Epic that relates to a particular story or task on the card however, it does not appear to have that option available. Is this possible? If so, what am I missing. Thanks
Hello @Shari Fitz-Patrick ,
Welcome to Atlassian Community !
Please note that, as per the current design of Jira, you can configure cards on a board to display up to three additional fields. The fields can be different for the Backlog and Active sprints, if you are using a Scrum board.
To add fields to cards:
Additionally , you can refer this article Customize cards
Hope this helps !
BR,
Prerna
Adding to the answer from @Prerna Sony
What type of project are you using: company-managed or team-managed? You may find this information at the bottom-left side of the page expand area.
At this time, only company-managed projects support configuring card information.
There is a suggestion to add this feature to team-managed projects, however Atlassian indicated in August 2022 that they do not plan to do so at this time. Please vote for / watch that one to see any progress: https://jira.atlassian.com/browse/JSWCLOUD-17336
Did you catch the news at Team ‘25? With Loom, Confluence, Atlassian Intelligence, & even Jira 👀, you won’t have to worry about taking meeting notes again… unless you want to. Join us to explore the beta & discover a new way to boost meeting productivity.
Register today!Online forums and learning are now in one easy-to-use experience.
