Card layout view
Gal Fatal
November 26, 2023
I want to improve the card layout using cloud and company-managed projects.
See the below example.
I added two fields: the original estimation and the remaining estimation.
I want to add my custom words to describe the field.
How can I improve improve the layout display in general? Any app that may support?
Thanks, Gal
Jack Brickey
November 26, 2023
Hi @Gal Fatal , I am not aware of any addon apps that would allow you to add the field names or aliases of the names n the card layout. I did a quick search just to check and nothing turned up. One consideration is to use dashboards or the Issues view to show that data which would have column headings.
Gal Fatal
November 28, 2023
Thanks @Jack Brickey Hope Atlassian will improve the layout customization options. Users want to change the color,the location, and add pre or post text to the card layout fields.
Like ddlaer0 likes this
