You can use the company manage Project template while creating project so you will get the specific kind of template for all your project.
Accept the answer if it helps
Can you share Issue Layout between Software and Business (previously Work Mgmt) Projects, as long as both are “Company-managed” projects?
Both of mine don’t recognize the other being something it can “Copy Issue Layout To,” even though all other schemes (Issue Type, Screen, Field Configuration, etc.) are shared between them without issue.
Anyone know why? Doesn’t seem to make any sense.
