Hello I have the below step and during this step I have a screen to add a link but jira.permission.link.denied is set on the status current. Can I disable this during the transition to be add to a link?
I want to see this
If you have that property set on that status, what is the scenario where you want to change it for the looping transition? Do you have Conditions on that looping transition that restrict who can access it, and those who can should be allowed to add links? If you have such a condition, what is the Condition exactly?
The idea is that the status current is locked for editing and adding links. And the current to current, should be called add task, will allow for the button to be clicked and it asks for the link to be added then adds and locks it down again.
We want to protect the information at current and only have an add task button.
Thanks for the response
So far I have not found any method for changing a Workflow Status Property within a Workflow Transition, and I have not thought of a way to implement your use case.
Ok, thanks for looking, we will have to keep it a manually change with a maturity in-between to allow the properties to be opened up.
Still thinking about joining us for Team '25 Europe? Early bird has been extended for just one week! Now’s the time to lock in your lowest rate. Use code TEU25COMM-20 to save 20% at checkout. Hurry, this only lasts for 1 more week.
Learn more
