Hi @VRaoballa - To add new statuses, you need to edit the workflow to add the new status. At that time you can also place the status in the order you would like it in the workflow using the appropriate transitions.
Fists, you have to add the new Status fields (open, pass, ….):
Then, you can edit the workflow
https://confluence.atlassian.com/adminjiracloud/editing-an-issue-workflow-844500771.html
