Change time format from am/pm to 24h doesn't affect my instance
Patrick Roos
Hi
I want to change the time format from am/pm to 24h.
According to the documentation (https://confluence.atlassian.com/jirakb/change-the-time-format-to-24-hours-in-jira-734234435.html) I've changed the following:
Look & Feel Settings
But the changes don't affect my cloud instance.
Do you see here any misconfiguration?
Thanks for your help.
Kind regards, Patrick
Aivar H_
December 10, 2021
I really want 24h format! No any clear documentation how to achieve that.
Svenja
November 4, 2020
Hi @Patrick Roos,
under "Look and Feel" you choose dd.MM.YY
in you advanced setting I see dd/MMM/YY
Also what time format is set in you personal account settings? When you're in Cloud you need to double check you account information.
Patrick Roos
Hi @Svenja L.
Thanks for your your answer.
I've customized the advanced setting - but I don't affect my site :-( In the personal settings I've the same configuration like you.
My goal is to change this time format to 24h.
Thank you for your help.
Kristian Brødsgaard
May 5, 2021
We have the same issue, despite the docs saying "H:mm" should be 24h, neither "H:mm" or "HH:mm" work, all times are still in am/pm format.
Like # people like this
Jorge Luque July 6, 2021
I have the same issue, it looks like it might be related to the language that you have chosen according to their docs:
https://support.atlassian.com/jira-cloud-administration/docs/configure-the-look-and-feel-of-jira-applications/
If so, are they expecting us to change our language to something like Greek or Russian to get access to 24h format in the issue view?? That would be ridiculous, maybe it's time to create a feature request...
When you go to Settings > System > General Configuration > Advanced Settings, it also says the same ridiculous warning about time format being dependent on language preferences:
Like Kol Ismn likes this
Andrey Permyakov January 20, 2022
Were you able to resolve this issue without changing the language?
Kotarlic, Benjamin
October 11, 2024
If anybody still has this issue: My workaround was to switch from English (US) to English (UK) to have 24h time format.
