I've recently changed a project key, and I understand it takes a while to re-index.
Everything is working absolutely fine, and I made the change 10 days ago. However I can still see traces of the old project key in the Roadmap, Backlog & Active Sprint breadcrumbs.
Also, when selecting a sprint for a story the options still show the old key for the board that the sprint is in.
Is this expected or will the re-index eventually catch all instances of the project key?
Many thanks.
Hi @Matthew , that is strange indeed as it shouldn't take that long.
Have you tried clearing your browser cache?
Yes I have quite a few times, its weird huh?
It appears to just be the Board name that hasn't updated. The Project Key should be CIP, and all the epics & stories have updated fine. But wherever it references the board it uses the old Key which was ATH.
Do I need to change the Board Key somewhere else?
Thanks for your reply.
Yes, board names is another thing. Glad you found the reason.
Did you catch the news at Team ‘25? With Loom, Confluence, Atlassian Intelligence, & even Jira 👀, you won’t have to worry about taking meeting notes again… unless you want to. Join us to explore the beta & discover a new way to boost meeting productivity.
Register today!Online forums and learning are now in one easy-to-use experience.
