I've just updated to using the new issue view and noticed a difference while pasting in an image from clipboard.
In the old issue view after you save the JIRA issue you could select inside the description box and paste in a image from clipboard. JIRA would then present a dialog where you could change the name to something more descriptiive like 'Step 1 - Click add button'. This name would be then used as the filename of the attached image to the issue. This is especially useful when you record a defect after grabbing a screenshot.
In the new issue view this doesn't happen. My images are being saved without asking the filename as 'Image-20210323-053740.png' which is non-descriptive and not as helpful.
Is there a way to get the old behaviour back while still using the new issue view?
