hello friends
in workflow I have make status which is hiding for all users except one group users which is showing through post function for them.
after that i have got charts drop downs
any ideas ?
The burndown chart works off what you see on the board, with the important column being the very last column, the rightmost.
So there are three things to look at here
1. Is your last column set correctly? Contains all the status you consider an issue to be "done" in?
2. Are all the status (including your "hidden" one) mapped into the board columns?
3. Have you done something with your "hidden" status that hides the issues in it from users? If you have, then your board can't show the data on them in the board or charts. If "hidden status" just means "some people can't put the issue into this status", that's fine, it's not a problem as it's not hiding the issue.
