Checklist Custom Field with Default Values when Create Issue
Lê Đức Thắng June 6, 2023
Whenever I create a new Story, I want it by default to have a Checklist Custom Field called Definition of Done with default values like "90% Unittest", "Documents ready" ...
Oleksandr Siryi_Railsware_
Hey, @Lê Đức Thắng
You can use checklist plugins like Smart Checklist to create checklist templates. The app is also integrated with Script Runner, JMWE and Automation for Jira which means you can set up various automation rules where a checklist will appear based on issue type or content of the issue. You can read more about automatically adding a checklist here
Hope this was helpful,
Oleksandr
Thanks for answering!
Mine:Screenshot from 2023-06-06 18-07-45.png
Guide:
Any ideas why mine does not work as expected please? :(
Hey, @Lê Đức Thắng how are you adding the items?
If you are using the "add a checklist item" field from within the issue then you don't have to use any formatting for adding a status (you can for other things like deadline or tagging someone). Just type in your checklist items.
Looks like something is wrong with my Smart Checklist. I cannot create new items nor save the template.
See: Record
mariya.solovey June 8, 2023
Hey, @Lê Đức Thắng
Kindly, contact us at smartchecklist@railsware.com so we can investigate the reason and help you set everything up.
Mariya
