Cloning Tickets
Jesilyn Barnes March 15, 2017
Is it possible to add a new custom field for ‘Clone’ and check if it can be defaulted to Y while cloning?
Gaston Valente
March 15, 2017
Jesilyn,
There's no Issue Cloned event, you need to capture Issue Created with a listener and then check for certain parameters ( link type or summary i think )
Hope it helps
Jesilyn Barnes April 26, 2017
Thanks Gaston. I will try that
