Close sprint with inprogress issue
Moti Stein May 8, 2022
Every 3 weeks when I close the spring I left with few issues on QA/In progress that I want to move with the team to the next sprint (low priority issues).
But if the issue is 5 story points and most of the issue is completed (~3 of 5 story points completed) when I closed the sprint the whole 5 story points are not completed. and the graphs of velocity of the team showing that these issues are not working by the team.
What is the correct way to handle this? I mention few examples I think about.
Close sprint -> change story points -> start sprint
Change story points -> close sprint -> start sprint
Clone issues -> Done old issues -> close sprint -> update new story points -> start sprint
Trudy Claspill
I agree with @Nic Brough -Adaptavist-
In my opinion you need to look at why the stories are not getting completed in the sprint to which they are assigned and address that.
Is too much work getting assigned to the sprint?
Is work getting added to the sprint that is diverting efforts from the originally planned work?
Is the estimate of work effort not accurate?
You need to address the root cause of why the stories are not getting completed.
Maybe you need to break your stories into smaller scoped stories that can be fully completed within the sprint. Maybe you need to not let additional work get pulled into the sprint. Maybe you need to look at your effort estimating and work towards better accuracy.
May 8, 2022
The correct way to handle it is to not change anything.
The story was not completed in the current sprint, so it goes into the next one.  The estimate has not changed, so don't change it.
But than in sprint 1 I did small amount of story points and than in sprint 2 it will looks like I complete a lot of issues.
This way its difficult to understand the average amount of story points that fit to the team per sprint
May 9, 2022
But you did not complete the story. The estimation only looks at what you delivered.  Not what you claim to have worked, that is irrelevant.
Like • Jukka Nikki likes this
Register today
