Closed sprints showing up in JQL futureSprints() result
Julius Möhring
November 30, 2020 edited
I just started with integrating the structure plugin. When inserting issues using the futureSprints() JQL function and grouping the result by sprint, closed sprints are showing up as well.
Why are the closed sprints included in the futureSprints() JQL and how can I get rid of them?
Thanks for your help!
Julius
mogavenasan
January 6, 2021
Hi @Julius Möhring
It looks like this is by design and there are some workarounds; How to remove closed sprints from a structure:
As Piotr mentioned, for now, the workaround would be to use the (Hide Closed Sprints) generator as a quick transformation.
Quick Transformations: https://wiki.almworks.com/x/YLDrAQ
Currently, The Hide Closed Sprint generator only works when applied to a sub-structure (Insert > Structure)
Besides that, to avoid confusion for other readers, it's futureSprints() not featureSprints() - I spent quite some time finding this particular JQL function.
Moga
Read the story
