Hi all
In my Cloud instance, I am trying to @mention a specific user in an automation action using the smart value instructions outlined here.
So I went to my profile as instructed and took the last part of the URL as below
to use in the format [~accountId:7120...a8f] which resulted in this:
I note that in my URL there is a % rather than a : as per the Atlassian instructions. Out of interest I replaced this but that didn't work.
Does anybody have any idea what I'm doing wrong, please?
I managed to do this easily in Server but have just moved over to Cloud and trying to re-create all my existing automations.
Thanks heaps, Brendan
Those Atlassian-provided instructions will lead to an encoded value for the browser URL, and the rule will not take that.
Instead please try this:
Thanks so much Bill, that worked.
Interestingly, the URL format was only a few digits off the new/correct value. If I replaced %3A with a colon it would have worked. I wonder if that's all or just for me... time will tell.
Not sure why they make finding the account id so obscure!
Cheers Bill
