Code snippet in Jira issue doesn't show once text box is saved
Peter Gebhard
May 5, 2023
I have added a code snippet in a Jira issue (see below):Screenshot 2023-05-05 at 2.25.55 PM.png
When I save the text box, however, the code snippet doesn't render/display (see below):
This doesn't seem like the intended behavior. I would expect the code snippet to render in a similar way to the preview mode where I typed the content.
Peter Gebhard
May 23, 2023
It seems to be working now. It must have been a small bug that got resolved quickly.
Esther Strom
May 5, 2023 edited
Hi, @Peter Gebhard - can you post a screenshot of what your field (assuming you're putting this in the Description?) looks like in Edit mode? I'm able to format code in my Description and it renders correctly, but it doesn't look like yours (there are no line numbers.)
I'm wondering how you inserted the code; did you just type it in and then highlight it and select the Code option?
2023-05-05 15_16_20-Esther's Classic Kanban - Agile Board - The Jira of Champions - Brave.png
2023-05-05 15_18_08-Esther's Classic Kanban - Agile Board - The Jira of Champions - Brave.png
ETA: I also tested it using the Code Snippet insert, and it formats and renders correctly.
2023-05-05 15_19_40-Esther's Classic Kanban - Agile Board - The Jira of Champions - Brave.png
