Compare issue created date with specific dates in automation rule
Pramodya Gamaethige
I need to check whether issue create date is equal to number of specified dates and send email to specific users by creating an automation rule.
Appreciate your support
August 26, 2021
Hi @Pramodya Gamaethige
For a question like this, please consider posting an image of your automation rule and the audit log.  That will help the community to offer you ideas.
If you have not started a rule yet, please look at these sources and examples in the template library to help:
Best regards,
Pramodya Gamaethige
August 27, 2021 edited
in my automation rule, Im trying to compare issue created date and a specific date and the audit log says the condition does not match.
August 27, 2021
Thanks for that info, @Pramodya Gamaethige
Have you tried to use the exact same date format for the comparison?  I note you are formatting one date with jiraDate and allowing the other to use whatever the function selects.
And if you want to compare to a specific date, have you tried a specific date as a string value, such as "2021-08-26" and compare to the approach date format?
One more note: when first creating a rule, it can help to split complex condition tests up into individual conditions.  You may more easily see if issues meet/do not meet the conditions in the log.  Once everything is working, bundle them together, as needed.
Like • Pramodya Gamaethige likes this
Pramodya Gamaethige
@Bill Sheboy Thanks for your advices. ill try change it to a string.
Learn more
