I'm having a problem.. Components field can't be added to a business project form. Any solutions or workaround please?
Best,
Tomas
Hello @Tomás Garzón
That field is not supported for Jira Work Management forms.
This page provides the details on the supported System fields and custom fields.
https://support.atlassian.com/jira-work-management/docs/manage-your-form-fields/
The workaround would be to create a custom field of the type Select List (multiple) to serve a similar purpose to the Components field, and add that custom field to your form.
