  • Community
  • Q&A
  • Jira
  • Questions
  • Configure Custom Field: How to make custom field a must for user to fill in before submit ticket
PINGCHUA
August 23, 2021
How to make custom field a must for user to fill in before submit ticket.
2 accepted
Andreas Springer _Actonic_
Go to the Jira settings in the top right corner and select Issues. On the left sidebar under fields, select field configuration. Click configure next to the field configuration you want to edit. You will see "Required" next to fields that have already been selected. To remove the requirement, just click optional.
Nic Brough -Adaptavist-
August 23, 2021
Go to the project settings and find the field configuration scheme.  You can flag the field as "mandatory" in there.
PINGCHUA
August 24, 2021
Thanks for the advice. It helps.
