I want to add a column in the list of subtasks which is displayed when I view a task. Default columns are:
issuetype, status, assignee, progress
(settings under General Configuration->Advanced).
I have tried this:
issuetype, status, assignee, progress, fixVersions
and restartet Jira, but no luck.
This is confirmed to be a bug:
https://jira.atlassian.com/browse/JRA-25343
The columns have to be configured in jira-config.properties. Edit them in GUI have no effect.
Is this still a bug? It looks like the issue has been resolved, but I'm still not able to add a custom field to this setting.
try fixversion or fixversions - although I've not tried it in the latest releases of Jira, when you do this in the application properties files, it's case sensitive and it expects lowercase.
I've tried lowercase fixversions and fixversion, but the GUI gives me the error:
The following fields are invalid: fixversions
I'm setting this in the GUI (General Configuration->Advanced). Do I have to set this in the properties file?
I can't find any documentation of which fields are available.
I'm using Jira 4.4.
Try fixVersions
Oops, that is what you tried initially! Hmm, wonder why that didn't work!
Does the field contain data? Do you have versions defined?
Register now
