Configure condition of transition
Onur Cevik
Hey!
I want to configure a condition of a transition. The condition should allow only certain issue types to move to the column. Does someone know how to do it?
3 accepted
Fazila Ashraf
February 13, 2023
Hi @Onur Cevik
You could use the below condition and configure it to match the issue type value
  Value Field Allows to execute a transition if the given value of a field is equal to a constant value, or simply set.
Onur Cevik
Hi @Fazila Ashraf
Sory but I don´t get it. I can compare some fields as condition but I´m interesetd to the type. I don´t know how to do it
John Funk
February 13, 2023
Hi Onur,
Edit your workflow and select the transition to the status you want to control (i.e. click on the line). Then click on Conditions in the right side.
Then click on Add Condition and Select Value field.
There you can select Issue Type for the field and then the value that you want to allow. See screenshot below. You will need to add a Condition for each issue type.
Onur Cevik
Hi @John Funk
Thanks! I understand it but there is no option Issue Type to choose. I assume that I have to define a field called Issue Type, right?
John Funk
February 13, 2023
No, that is a built-in system field. You can't function without that field in the system. Can you include a screenshot?
Like Onur Cevik likes this
Ashish Bijlwan
February 13, 2023
Hi @Onur Cevik
As @Fazila Ashraf mentioned, please use "Value Field" condition and in Field select Issue Type and under value type the Issue Type name to allow to move the transition. Below is the screenshot for your reference:
Thank you,
Ashish
