Configuring automation triggers between two or more sub-tasks
Italo Gonsalves August 6, 2020
When creating tasks I will have multiple sub-tasks within that task. I'm trying to accomplish the following.
-When sub-task (A) status transitions to DONE.
TRIGGER
-Currently unassigned sub-task (B) with specified assignee.
*Each sub-task involved has a unique "issue type" and "workflow" associated.
Current automation rule is as follows.
-When: Issue transitioned FROM (X) to (DONE)
-If: Sub-task present
-And: Issue type = (Y)
-Then: Assign the issue to (Z)
I gather since the automation is working by a direct parent>child rule its not acknowledging sub-task (B) as (B) isn't the child of sub-task (A).
Is there another way to accomplish this?
Italo Gonsalves September 2, 2020
Ok thank you for all of your help John!
John Funk
Hi Italo - Welcome to the Atlassian Community!
Is there some type of established relationship between Sub-task(A) and Sub-task(B) since it appears that they have different parents?
Italo Gonsalves August 7, 2020
Thank you John! Great to be here.
They are both Sub-tasks of the same parent Task.
I'm trying to leave (B) unassigned until (A) status changes to DONE at which point (B) gets an assignee. The assignee's start work as soon as they get their Sub-task assigned.
The main Task represents a fulfillment work order. The Sub-tasks are situational and are created manually when the main task is created. Some Sub-tasks auto assign when created based on post function triggers. Some Sub-Task need to wait until a previous Sub-task is completed to be assigned and due to their situational nature I'm not able to merge the two Sub-tasks into one workflow.
I created several unique Sub-Task issue types, each with unique workflows.
Thanks for the feedback!
John Funk
So something like this:
A transitions to Done.
B is then given an assignee (is specific name is included in the automation or is the assignee based on another field?)
Is B then automatically transitioned to a new status?
Do you have the rule created already? If so, can you share it?
Italo Gonsalves August 10, 2020
Yes sir. Yes the specific name is included. (B) does not transition to a new status. It remains in OPEN status.
The rule is as follows:
When - Issue Transition: From POS training to DONE
If - Related issues condition: Related issues = Sub-tasks > Condition = Are present
And - Issue fields condition: Field = Issue type > Condition = equals > Issue type custom NAME
Then - Assign issue: Assign the issue to = Specific user >select user = Italo Gonsalves
John Funk
Sorry for the delay in responding. Is the above process working for you? Or are you getting an error or it just doesn't work?
Italo Gonsalves August 14, 2020
Hi John. It just doesn't work.
I need some way to relate both sub-tasks to the parent main task. Since Jira issues a unique ticket number to all tickets whether main task or sub-task I'm having a hard time associating the family of tasks together.
Furthermore I'll want to make sure that if I have multiple main tasks w/ children sub-tasks that have "status changes" which trigger automation, those triggers are staying within the unique family of tasks. I wouldn't want the status of (MT-21) transitioning to DONE to trigger (MT-32) to assign user.
example:
MAIN TASK (jira ticket#) = MT-20,
Sub-Task (A) (jira ticket#) = MT-21,
Sub-Task (B) (jira ticket#) = MT-22,
-Family of Tasks for (jira ticket#) MT-20-
MAIN TASK (jira ticket#) = MT-30,
Sub-Task (A) (jira ticket#) = MT-31,
Sub-Task (B) (jira ticket#) = MT-32,
-Family of Tasks for (jira ticket#) MT-30-
John Funk
So you want to be able to link MT-21 to MT-22 for purposes of doing some automation to one or the other?
Yessir. That is correct.
I attached the audit log details below.
John Funk
That's a little bit complicated.  :-)
What about something like this:
Italo Gonsalves August 20, 2020
Thank you John! Sorry for the long delay.
I feel like this is getting me closer to the goal. It didn't quite get me there yet.
The automation is now failing here.
{{triggerissue.parent link}} = {{issue.parent linkl}}
Is there something specific that I should reference here?
The trigger issue is Sub-Task (A)
Thank you!
John Funk
Can you provide more information about the failure? What does the Audit Log say? Also, have you verified that the parent for both the issue and the trigger issue are the same?
Italo Gonsalves August 21, 2020 edited
Hi John,
 Yes the Parent is the same I attached the parent ticket example with its sub-tasks along with audit log.
Parent ticket = PS-117
Trigger Subtask ticket (New) = PS-122
Target Subtask ticket (Digi$shield) = PS-123
John Funk
Is the issue type actually called DigiShield? Or is that just the name of the ticket (the value for the Summary)?
Italo Gonsalves August 31, 2020
Hi John, It is actually called Digi$hield.
I created a new subtask type and named it that.
John Funk
I would go ahead and submit a support ticket with Atlassian. Then please post back here what the resolution was.
https://support.atlassian.com/contact/#/
Jillian Amyot _Unito_
Hi @Italo Gonsalves ! Check out Unito, where you are able to sync the two so when it becomes finished in one category it gets sent to the next. Here is a link that might help you :)
https://unito.io/jira-sync/
