Considering Script Runner for 5 use cases
Kian Pariwar
we currently have 5 use cases, which we are seemingly not able to solve with JIRA Cloud out of the box.
Script Runner seems to be the plugin that could help us out, but as I do not know the plugin, I would like to check with you guys beforehand. We have the following 5 requirements:
  1. Parent Tasks and Sub Tasks share the same screen, are shown on separate boards (configured via board filters) but follow different workflows (5 step workflow for parent vs 3 step for sub). It is important for us that all values populated in custom and default fields are inherited by the sub tasks.
    1. It would be nice that the inherited values are then set to read only (but not must have)
  2. Make specific custom fields mandatory if a certain value has been chosen within another custom field
  3. Add read only text fields
  4. Automatically create a certain set of sub tasks when the parent task has transitioned within the workflow
  5. Automatically change parent task status, when changing status of one or more sub tasks. E.g. if subtaskA is moved to the column Done, then the parent task should move automatically to the next column in the parent task board.
Is this generally doable with script runner?
Regards
Kian
3 votes
Jon Bevan [Adaptavist]
November 9, 2016
Hi @Kian Pariwar,
  1. Using ScriptRunner for JIRA Cloud you can configure post functions on transitions or event listeners (for e.g. create issue events) to populate subtask fields with the values entered in parent fields
  2. Atlassian don't provide any way to customise the create or edit screens, so this isn't currently possible
  3. I don't think this is possible either for the same reason as 2
  4. This can definitely be achieved using a ScriptRunner post function
  5. This can definitely be done using ScriptRunner
Hope that helps! Don't hesitate to ask if you have any more questions,
Jon
Kian Pariwar
Hi Jon,
thanks for the clarification.
One more question regarding my point 4 above:
  • We have several country teams, for which we would need to create separate sub tasks. The only way we know which country team needs to work on a sub task, depends on the value(s) selected in a "Select List (multiple choices) custom field.
  • E.g. if a parent issue is created where countries UK, US and France are selected, we would need to create SubTaskA 3 times (one for each selected country)
  • Nice to have feature: Each sub task inherits one of the selected countries in the Country field (it is the same custom field as in the parent task), so that it is directly clear, which sub task belongs to which country.
Is this also realizable with ScriptRunner?
November 9, 2016
Yes that's definitely possible. When creating the subtasks for each country, you can set a custom field to be the value of that country.
Kian Pariwar
just to be clear:
The sub task creation is not performed by me but by scriptrunner. ScriptRunner does not only need to auto create sub tasks when a parent task has transitioned, but it also needs to check the country custom field and create the same set of sub tasks multiple times, if several Countries have been selected. When doing so, it would be nice, if it also could prepopulate the custom country field with the country it created the sub task for (so not all 3 countries but only one of those for each auto-created sub task).
November 9, 2016
Apologies - when I said "you can set a custom field" I meant "the script that is run by ScriptRunner can set a custom field".
On the parent transition, you would have a postfunction that would read the countries out of the custom field on the parent issue, then create a subtask for each of those countries, setting the value of the custom field on that subtask to be the country the subtask was created for.
Kian Pariwar
Sorry, one more use case just came up:
6. Every Monday, a specified set of parent and sub tasks needs to be created at 8am
Does scriptrunner support this kind of  autocreation based on a predefined schedule?
November 13, 2016
At the moment we have no support for scheduled tasks in ScriptRunner for JIRA Cloud. I'll bring it up at our planning meeting later today.
Register today
