Convert string to a specific value
Wolff Sébastien
June 6, 2024
I have a select list (single choice) with this different choices :
- Minor
- Major
- Critical
I need to use this field in an automation to calculate another field on the request.
For this, i need to create a variable to set the numeric value for each option.
- Minor : 1
- Major : 2
- Critical : 3
Is there any function to create this variable ? I try to use the function "if" when i create the variable, but it doesnt work.
Thank you for your help.
June 6, 2024
Hi @Wolff Sébastien -- Welcome to the Atlassian Community!
There are several ways to do this:
  • if / else conditions
  • conditional logic
  • lookup table
I recommend trying a Lookup Table for this: https://community.atlassian.com/t5/Automation-articles/Update-Create-lookup-table-action-improvements/ba-p/2427798
For example, the table keys could be the name for the possible selections and the value could be the number.  Then the get() function would return the value:
{{tablePriorityToScore.get(issue.myCustomField.value.name)}}
If that does not help, please post an image of your complete automation rule and audit log details to provide context for the community to offer suggestions.
Wolff Sébastien
June 6, 2024
Thank you so much. It's work.
Like Bill Sheboy likes this
