Smart Value string functions
Dillon Weyer
Hi All,
I have a custom field for the team name. I have set up an automation to clone an issue when this custom value is set. ~I found an article which described how you could use string functions to use part of a custom field to set a smart value. In my case I want to create the issue in the related team's project. I updated the team's values and appended the project ID to the name e.g. Team Name - 10845
When I add the following to smart value, I get the following error:
The provided smart value was unable to be resolved to an object.
This is what I am using:
{{fields.customfield_10155.substringAfter("-")}}
Based on the following it seems like you can use these functions in a smart value:
Anyone able to offer any guidance of where I am going wrong please
Trudy Claspill
Hello @Dillon Weyer
I suspect this issue is that you specified fields rather than issue. Try making that change and see if your problem is solved.
October 19, 2022
Hi @Dillon Weyer
Yes, and...to Trudy's suggestion:
If you literally are using "Team Name - 10845" then your substringAfter should account for that leading space character, such as with:
substringAfter("- ")
By the way, for a question like this I'd recommend including images of your complete rule and of the audit log details showing the rule execution.  Those may provide more context for the community to help.  Thanks!
Dillon Weyer
October 20, 2022 edited
Thanks so much for the reply @Trudy Claspill and @Bill Sheboy I made the change as per your suggestion, but still getting an error when used as a smart value. For testing, I have included the following insert comment to validate what the value outputs are:
Team Project Code using team name field and using subString: {{issue.customfield_10155.substringAfter("- ")}}
Team name without subString: {{issue.customfield_10155}}
The first one returns the text but no value for the custom field
The second one returns the custom field fine.
I have also included screenshots now as per your suggestion:
-DFT-603-This-is-a-test-Jira.png Automation-Jira (2).png Automation-Jira (1).png Automation-Jira.png
Dillon Weyer
managed to get it to work, needed to add .value i.e
{{issue.customfield_10155.value.substringAfter("- ")}}
once again, thanks for the support
October 20, 2022
Well done, Dillon!  Any my error, as I should have asked if you had a single-select or text field; that impacts what is available in the smart values.
When in doubt of the smart values, or when something does not work as expected, this how-to article helps to find the supported smart values for an issue: https://support.atlassian.com/cloud-automation/docs/find-the-smart-value-for-a-field/
Like • Dillon Weyer likes this
Register now
